90 camaro 305tbi idle problems
Old Sep 11, 2009 | 07:38 PM
camarojunkie's Avatar
Default 90 camaro 305tbi idle problems
I have a 1990 camaro rs 305 tbi. If i am sitting at a red light for too long in drive the engine shuts off but cranks right back up. The timing is set to 0 degrees. I have cleaned the iac before seemed to help a little bit but that was about a year ago. Any suggestions would be appreciated.
Old Sep 14, 2009 | 07:07 PM
microkid's Avatar
March 2011 ROTM
whats your idle speed?
Old Sep 14, 2009 | 07:39 PM
hard to say the tach does not work, but if I had to guess I would say around 700-800rpm
Old Sep 14, 2009 | 09:04 PM
91ralllysport's Avatar
is that a normal idle setting cause i have a stock 350 that was swapped in my car (before i bought it) and it idles at 1000 when warm it statrs at 2000 to 2200 when first started
Old Sep 14, 2009 | 09:45 PM
Mine does about the same idles at 1000, when first started and warm it goes up to 2000-2500 for a few minutes then idles down to 1000. Like I said the tach does not work and I dont have an aftmkt tach
Old Sep 16, 2009 | 06:49 PM
microkid's Avatar
March 2011 ROTM
well if you cleaned the iac before and it corrected the problem, i suggest trying it again and see if it works. has the engine been given a tune up in the last few years?
Old Sep 16, 2009 | 06:59 PM
just did a tune up about a month ago
Old Sep 16, 2009 | 07:00 PM
im gonna try to clean the iac again
Old Sep 16, 2009 | 07:30 PM
microkid's Avatar
March 2011 ROTM
let us know if that fixes it or not
Old Sep 19, 2009 | 04:47 PM
cleaning the iac did not help a bit actually the pintle was clean
