93 Camaro lt1 Build, Craby's
Old Sep 1, 2009 | 02:13 AM
Default 93 Camaro lt1 Build, Craby's
got a major part in the build today. heads came back. first two pics are before. the rest are after lloyd was done. should get the intake back in the next day or two. got the 223/230 .565 cam, the stainless comp cam roller rockers, .0028 head gaskets, new stock oil pump, new head bolts, new main bearings, a few things like a new waterpump driveshaft, oil pump driveshaft and most of the gaskets i need. still need the push rods and lifters and once i get them ill just about be set to start. thinking of useing a 5.5 oil pan but not sure yet.
Attached Thumbnails 93 Camaro lt1 Build, Craby's-heads-before-work1.jpg   93 Camaro lt1 Build, Craby's-heads-before-work2.jpg   93 Camaro lt1 Build, Craby's-heads-after-work-1.jpg   93 Camaro lt1 Build, Craby's-heads-after-work-2.jpg   93 Camaro lt1 Build, Craby's-heads-after-work-3.jpg
Old Sep 1, 2009 | 07:28 AM
torque_is_good's Avatar
I'm jealous. This makes me want to do mine but I'm actually starting to look for another 4th gen for a project and this time I"ll probably get an LS1.
Old Sep 1, 2009 | 08:59 AM
whammer3024's Avatar
ROTM Winner
i hate you right now...lloyd does great work...i didn't know you were doing any build. are those le2 heads?
Old Sep 1, 2009 | 10:21 AM
yes le2's with patriot gold springs.
Old Sep 1, 2009 | 02:43 PM
ROTM Winner
yeah pretty sure i hate you. why haven't you told us about this build until now?
Old Sep 1, 2009 | 03:04 PM
well i have just not in a separate thread. i have a new crate lt short block but its been setting for 12 or 13 yrs so i am replacing the main bearings just to be sure they werent damaged by the crank setting so long in one place. should be lookin at close to 400 hp when done. have 30lb injectors to put in and will pick up a 58mm tb to go with it. the motor will not go in till i can afford the exhaust and trans. so far kooks headers and catted y pipe and corsa cat back for exhaust and a raptor level three from patc. im thinkin next summer it should be goin in. then its hope and pray the rear end will hold till i can afford the 12 bolt 373s from spohns.
Old Sep 1, 2009 | 03:13 PM
robmnrd's Avatar
Hey...this build sounds kinda familiar...le2s, a relatively small cam (mine's smaller. ), sprung for the intake/tb as well even though most people will tell you it's a waste 'til you're pushing about 500 horses at the crank....yep...we've got some similarities! haha
Get the flow numbers up! I wanna see how they compare!
Old Sep 1, 2009 | 03:29 PM
soon as i get her up and running ill be goin up to oly and doin the dyno at horsepower connection. lloyd told me to use the 58mm so thats what im doin. i have it tuned for the 50mm tb with the 30lb injectors that are on it now and it did make a difference. not allot but noticable.
Old Sep 6, 2009 | 03:14 AM
got the 96 intake manifold yesterday from lloyd. ordered the roller lifters and will order the pushrods after i get the rod length measured.
Intake
fully ported
enlarged runners
58mm tb opening
LT1 LE2 heads
manley 2.00/1.56 6000 series valves
patriot gold extreme springs (155 lbs seat and 400 lbs open)
205 cc intake port
flow about 275/190 CFM
bullet racing cam grind #CLT276/281-12HR
223/230 .565/.565 112 separation
comp cam roller rocker arms
1.6 7/16 pro magnum
GM performance composition head gaskets
part # 12553160
.028 compressed thickness
Attached Thumbnails 93 Camaro lt1 Build, Craby's-build-parts-pile.jpg   93 Camaro lt1 Build, Craby's-intake.jpg
Old Sep 29, 2009 | 04:11 PM
Default lt1 build
got the heads, cam, lifters, pushrods and rockers on. starting to look like a motor.
