mounting rear spoiler
Old Mar 2, 2005 | 04:53 PM
mvsjr's Avatar
Default mounting rear spoiler
looking for a template of mesurements of mounting the rear spoiler on my 69 camaro if anyone can help me ou tplease let me know thanks J.P. CAMARO4LIFE...............................
Old Mar 17, 2005 | 02:15 PM
mnyfrnds's Avatar
Default RE: mounting rear spoiler
I mounted one on my 68. it was pretty easy. I layed the cardboard that it came in on a flat surface. Then I placed the spoiler over the cardboard with the studs on the cardboard. I pressed hard enough to dent the cardboard. Then I cut the holes out where it dented the cardboard. I tried to keep them small for a tight fit. Next I put the cardboard back on the spoiler and pressed it all the way to the plastic. I then traced the spoiler from the top side and cut out the cardboard. That's what I used for a pattern. I placed the cardboard on the trunk, marked the holes drilled & bolted the spoiler on. It worked pretty good. Only one hole was off abou 1/8 inch. I opened it up with a dremel.
Old Jun 28, 2005 | 11:42 PM
motoxer0890's Avatar
another easy way to do it is put some grease on the end of the studs and put it on the cardboard then drill where the grease is .
camaroteen82
Jan 3, 2014 04:10 PM
ta2mikep75
Jan 10, 2013 11:10 AM
mikes68
Aug 30, 2012 08:12 PM
Barkat
Sep 28, 2010 06:27 AM
sprice73
Jul 3, 2006 03:32 AM
