perfomrance cams
Old May 19, 2006 | 02:37 AM
littljohn's Avatar
Default perfomrance cams
what would be good cams to put in a 79 z28?
Old May 20, 2006 | 11:53 AM
Default RE: perfomrance cams
First you only have ONE cam. Second I need to know all your mods including trans type and rear gear ratio to give you even the slightest idea.
Old May 20, 2006 | 09:32 PM
TimmyTheWop89's Avatar
cant really give you much of an estimate out of what you said, but if its a street machine that will be a comfertable drive, go with a hydraulic cam and lifters with a duration from 210-220 and a lift a little under .490, but we do need more info to help you best, thats jsut a fair street cam.
Old Jul 12, 2006 | 07:58 PM
littljohn's Avatar
the transmission is BorgWarner Super T-10 jsut rebuilt. im nto sure what it all has it sounds like it has a modfied cam but im not sure i jsut bought it and i can't get ahold of the guy, but it has a holley 4 barrel not sure what cfm endelbrock manifold not sure which kind, headers and flowmaster exhuast, i dont no the reaer end when i burn out only one tire spins so iwill probably get a new rear end. any ideas?
Old Jul 12, 2006 | 10:33 PM
Timmy's suggestion above is a good one. You don't want to over-cam it, too much cam is a common mistake and will hurt performance.
Old Jul 13, 2006 | 04:12 AM
littljohn's Avatar
ok thanks for all of the information it will be helped greatly, i have another question when im at lower rpms and floor it it makes this clicking noise but once it gets higher rpms either i cant here it any more or it goes away any ideas?
Old Jul 13, 2006 | 11:40 PM
Header leak maybe?
Old Jul 14, 2006 | 04:43 AM
littljohn's Avatar
thats whay i thoguht too there brand new headers. my cousin has a 79 but its not a z28 and he said it makes the same sound, i have to put exhaust manifolds on for smog so ill seeif that fixes it and my car isnt that fast ithoguht it would be faster, i raced my buddies stock 1990 300zx and he smoked me so i was wondering if thats normal or if soemthign might be wrong
bobc04
May 6, 2009 01:22 AM
94camarokid10
Jan 28, 2009 09:14 PM
FearThisInc
Oct 10, 2008 04:31 AM
Camaroslpss
10
Sep 17, 2007 06:43 PM
Camaroslpss
Jul 30, 2007 09:14 AM
