headers vs. aftermarket cat. convert.
Old Apr 25, 2006 | 02:51 PM
akohnz's Avatar
Default headers vs. aftermarket cat. convert.
I have an aftermarket cat. converter on my 94 z28. I was pinched for money so I had it welded on instead of replacing the y-pipe. Would it be a bad idea to put headers on the car? I dont want too much pressure on that cat. if it cant take it. Thanks!
akohnz
Old Apr 28, 2006 | 12:13 PM
shnormo's Avatar
Default RE: headers vs. aftermarket cat. convert.
Is it just a cheap catalytic converter? It should still be able to be used with headers because it doesn't increase the pressure, it lowers it and has a higher rate of flow. It also just helps equalize the exhuast puleses from the engine.
jd326
Dec 2, 2011 04:01 PM
bashgod
Oct 31, 2010 02:10 PM
tylerparson
Aug 31, 2008 10:21 PM
92camaroRS
Aug 11, 2006 11:50 PM
