Bad Transmission???
Old Apr 16, 2006 | 11:42 AM
sonicdrft's Avatar
Default Bad Transmission???
hi my friend has a 95Z28 with and automatic trans..the car was sittin for a lil while because of a bad fuel pump and when he finally fixed it he went to drive and the car wouldnt shift past 2nd..but still has reverse...please help..thanx
Old Apr 16, 2006 | 03:19 PM
SickSickSick's Avatar
Default RE: Bad Transmission???
First Of All It Probably Needs The Fluid And Filter Changed ... Put It In Reverse Get It Up To About 15 Miles Per Hour Stop. Put It In Drive Get Up To About 15 Miles Stop. Do It In Reverse Again. Do This Several Times. Then Try It. Don't Over Rev But, Try And Keep It At The Point It Should Shift At. It Should Go Ahead And Eventually Shift. It Will Get Better With Time. I've Had This Happen Several Times On Older Trannys That Have Sat Up For A While. Also Make Sure The Lockup Wires Going To The Tranny Hasn't Got Unplugged Somehow. That Will Cause Delayed Shifting. Sick
Old Apr 21, 2006 | 04:10 AM
sonicdrft's Avatar
ok i got it wrong...the problem isnt exactly what i said..the problem is that the car doesnt make it to second gear...
Old Apr 21, 2006 | 09:32 PM
Still Try What I Suggested . You Can Also Sniff The Dipstick. If The Tranny Is Toast It Will Smell Like Burnt Clutches If Not It Will Just Smell Like Fluid. Sick
Old Apr 22, 2006 | 04:24 AM
SickSickSick, I am going to have to ask that you make your sig smaller, we really don't have a size limit here yet, but try and be reasonable.
Thanks
JD
Old Apr 22, 2006 | 02:13 PM
TimmyTheWop89's Avatar
i would say a vacuum line problem but if it were that, it wouldnt change into 3rd. i would go with what SSS said.
Old Apr 22, 2006 | 11:58 PM
tsinn13's Avatar
Yeah I would def. agree with what sick said , if that doesn't help try looking at the servo on the side of the tranny sometimes they get sludged up when they have been sitting for a while , again the fluid and filter may need to be changed but definetly don't rule out the servo.tsinn13
Inked88
Jul 27, 2011 10:57 AM
dsinclair999
Feb 21, 2011 11:24 AM
randolphdelpriore
Jul 4, 2008 11:05 PM
DeputyDog
May 22, 2008 02:45 PM
camaro girl
Apr 8, 2007 04:58 PM
