Carb issue-Theft!
Old Sep 20, 2008 | 01:28 AM
pan5074's Avatar
Default Carb issue-Theft!
My 69 Z28 was in the shop getting paint.Had to be left alone for too long.Between the tow truck driver and the vinyl top guy somehow I dont have a DZ carb anymore.I'm now the proud owner of a 650 Holley double pump.My question is this....I have pulled it off and placed it in a shop to be rebuilt.The original DZ carbs were 850 cfm were they not?Will this 650 cfm work with my 302?Should I bite the bullet and get another DZ 850?Very frustrating to say the least.I did an intro a long time ago but forgot my password.Thanks in advance guys!
*Edit* Just realized this is kinda a loaded question.The z would run with the 650 on there but it would cut out at high rpm's.Like right before you would shift.Also it loaded the engine with fuel(oil pan and all)so I pulled it to rebuild.This is when I realized it wasnt the DZ holley.Also this was only within 100 miles of getting it back from the vinyl shop.So,just wondering how the carb would do performance wise I guess.
Old Sep 21, 2008 | 07:38 PM
Ircyklops's Avatar
Default RE: Carb issue-Theft!
Actually, the original Z28 302 carbs were 780 cfm with vacuum secondaries. The 650 double pumper should perform very close if it is jetted properly, since it will actually flow a little more than 650 cfm.
Old Sep 21, 2008 | 08:33 PM
pan5074's Avatar
Right on,thanks for the info!I was curious if the 650 would do the job(answered) and what the main jet should be as well?
gfrench
Sep 12, 2011 05:51 PM
mjlynch71
Apr 27, 2010 10:50 PM
Goodfella
Dec 20, 2006 10:54 PM
