more power dah!!!!
Old Nov 22, 2004 | 05:21 AM
pro_engines244's Avatar
Default more power dah!!!!
ok anyways heres my guestion i have a 90' camaro with 350.. i was wondering what would be the best way to get her up to around 500hp.. liek what parts and about how much do u thinkit would cost.. i was also wondering what is the highest compression i can run with pump gas i think premo is 91 in cali.. i was thinking somewhere in the 10's would be fine.. but what other parts should i get like which head do u prefer and what cam.. what header ex... anyways just want to make a nice *** camaro always been my dream.. and i wanna go make the ricers cry.. so any help we be very good.. thanx
Old Jan 16, 2005 | 06:15 PM
spdshftr's Avatar
Default RE: more power dah!!!!
is it carb or fuel injection???
Old Apr 25, 2005 | 09:00 PM
erik\\\\'s Avatar
Bottom end bottom end! for 500hp
i would buget around 3-5 grand if i'm turning the renches
Old Jun 23, 2005 | 01:53 AM
blue94z28's Avatar
Nitrtous.
Old Jul 4, 2005 | 04:49 AM
Ponykiller's Avatar
for that kind of power, you will need to build it from the ground up. you will be safe on 11:1 compression, just don't go crazy on the timing. also before you dump all your money in the engine, build your drivetrain and rear end first, nothing like dumping all that power only to blow the rear end on the first pass. good luck
Old Jul 4, 2005 | 05:41 PM
Camarok's Avatar
well your asking a high price, nice to know you have a dream but depeends on the power your running now and if the enigine can handle it? well its it carb? and is it a damn crate motor cause your pushing nowing then, you going to need nice heads along with a shot of nitrous to bump up, what kind of engine is it? you going to need to know the eingine back and forth to know wjhat to expect from it! sounds like a plan but camaros are heavy cars, usually 4k, so your going to have to lightening soething and mabye try to disconnect something your not using or need, do you want horse or a fast car? if its heavy, its not going to be very effective.... nicew plan tho
MaxTheKiing
Aug 23, 2010 03:21 AM
rbeard
Aug 9, 2009 12:11 AM
dkblind87
Jul 27, 2009 05:35 PM
IBADRIDE
Jul 13, 2006 01:44 AM
