Chevy 302 questions
Old Feb 8, 2008 | 06:16 PM
WideLowandFast's Avatar
Default Chevy 302 questions
I recently pulled an engine out of my friends backyard. I tore it down lastweek and started researching the casting numbers. The casting number on the odd numbered cylinder side of the block behind/below the distributer is 3914678. The date code is F 188 (June 18,1968) and it has a sufix code of MS stamped on the deck (even nubered cylinder side). The pistons I punched out were .030 over so it has been punched out. The block hasn't been decked though. My question is: could this be a '68 302 or maybe a Vette 327, or is it just another 350 out of a Chevelle.... This is a great site. Lots of info. If anyone can shed some light on the subject it would be greatly appreciated. Thanks.
Old Feb 8, 2008 | 11:39 PM
Default RE: Chevy 302 questions
1968 350, 2 bolt main, 295 hp, 4 barrel, Camaro/ChevyII, manual trans.
Old Feb 9, 2008 | 05:22 AM
MichiganMan's Avatar
January 2008 ROTM
ORIGINAL: Camaro 69
You sir are right on the money
Old Feb 9, 2008 | 11:35 AM
Thank you for your input guys. That was kinda the way I was leaning too.
Old Feb 9, 2008 | 01:39 PM
January 2008 ROTM
if the block wasnt decked what are the # on the pad ?
Old Feb 9, 2008 | 05:14 PM
I've got that all written down at my shop. I'm going in for a bit tomorrow. I'll be sure to grab it and let you know.
Old Feb 12, 2008 | 04:11 PM
The numbers on the pad are as follows 18N475006 V07I5MS F18 8 and the little watch face stamping is pionting to the 6 o'clock position. If any of this information is helpful let me know. Also with the 3914678 casting numbercould this number also translate to a 302?
Old Feb 13, 2008 | 06:51 AM
January 2008 ROTM
ORIGINAL: WideLowandFast
That casting was used with 307 327 302 350 engine's.... VO715MS < Sorry this is designated as a 350. I just needed the # for my records.
Adam78
70-81 V6/I6 Tech
Jan 20, 2013 11:08 PM
astephens830
Jul 21, 2011 05:57 AM
tjsmar
Mar 28, 2011 05:28 PM
childofjuly
Aug 13, 2008 02:06 PM
