Camaro engine code information
Old Jan 26, 2008 | 09:02 AM
MTH trains's Avatar
Default Camaro engine code information
I have a chevy SB engine that came with a 1969 RS/Z-28 I purchased in 1979. I was told that the engine came from wrecked 1969 Camaro. I have long since sold that car, but still have the block and crankshaft. I think that I have the crank I.D. figured out as this has a casting no. of 1178, but the block is the one that has me confused, and I hoping someone here can send me in the right direction.
The casting number on the block is as follows:3959512, which from what I've found on the casting lists shows this engine as a 1962-1963 327 2 bolt main, yet this is a 4 bolt main engine.
The date code on the engine is: K68
The engine ID code is: V1I19DZ 19N550021
Any help on this would be appreciated.
Thanks, Scott
Old Jan 26, 2008 | 09:18 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: Camaro engine code information
The sites I checked all has it as a 327 2 bolt also. So the 4 bolt main is confusing.
Old Jan 26, 2008 | 03:08 PM
MichiganMan's Avatar
January 2008 ROTM
got any pics of those #'s would love to see them also if possible 3959512....327...62-67...2.bolt..Was also used for some "CE" replacement blocks Ya got me definetly something messed up there. for starters a 327 wouldnt have aDZ STAMP 302 would
Old Jan 26, 2008 | 05:55 PM
January 2008 ROTM
I would have to see the pic's of the vin stamp sounds like a re-stamp so far. block casting defnetly indicates 327 2 bolt you say its a 4 bolt pic's? r u sure that you read casting correct?
Old Jan 26, 2008 | 09:17 PM
MTH trains's Avatar
I just checked again and maybe I'm missing something, but the only thing that maybe questionable is one number in the sequence 19N550021. I can take pics, but I'm not sure how to post them, but would be happy to e-mail them for someone to look at.
Thanks again I appreciate the help.
Scott
Old Jan 26, 2008 | 10:26 PM
MTH trains's Avatar
Sorry but this seems to be the largest size pic I can get on this reply. Hope you can see them.
Old Jan 26, 2008 | 11:26 PM
MTH trains's Avatar
These may be better.
Old Jan 27, 2008 | 12:14 AM
MTH trains's Avatar
A couple more
Old Jan 27, 2008 | 12:15 AM
MTH trains's Avatar
Last two.
Old Jan 27, 2008 | 08:17 AM
January 2008 ROTM
ok I have found some info here is a link that better shows what the 512 block is http://www.camaros.org/drivetrain.shtml#BlockCastI also have sent the pics to some very well know camaro guys that have a database for reuniteing motors to the original cars i there still out there.IT looks like you have a 302 motor out of a 69 z28 to me Ill post up more info when they reply to me
