fule pressure drops
Old Dec 16, 2007 | 01:57 PM
crusherdrivinfool's Avatar
Default fule pressure drops
ok I hope I am getting close to getting this thing fixed.
but the problem I have now is that when i first turn the key on the pressure jumps up to neer 50 but soon as the pump shuts off it drops rapidly and will only come back up if i crank the motor over.
What could cause the pressure to drop like that?
I had no problems with the pressure befor but had a bad injector so I took it all apart and replaced the injector put it all back together and now it just cranksand dose not start.
Old Dec 16, 2007 | 07:42 PM
Default RE: fule pressure drops
The pressure is under control of the pressure regulator, and is supposed to drop about 10 PSI after the engine starts. However; it is supposed to hold at the lower pressure once the engine is turned off. There could be a bad check valve in the fuel pump, a bad pressure regulator, a leaky injector, or a plain old fuel leak.
96z28richard
Jul 13, 2014 04:47 PM
jjcrago05
Aug 4, 2009 04:25 PM
nascar9
Sep 2, 2006 09:07 PM
nascar9
Aug 31, 2006 01:56 AM
dzroc
Jun 14, 2006 10:43 PM
