What part of the ECM....
Old Dec 30, 2005 | 04:28 PM
el_coqui's Avatar
Default What part of the ECM....
My nephew owns a V8 86 camaro. He installed a 350 HO motor with an Eldebrock carb, intake and a HEI distributor. Now the carb, intake and distributor are of the non-electronic type. He wants to remove all the computer system that are not being used, but we don't know what part of the computer system is being used. The distributer just has the power wire, tach wire and the electronic module wires attached to it and has a vacuum advance. The carb does not have any wires attached to it. The intake has a vacuum hose hook up to the MAP sensor and another device that looks like the MAP sensor, a hose to the power brake booster, one to PVC valve and one hose to the vacuum canister.
What system of th ECM is being used that we need not disturb? What can we get rid off?
Thanks in advance
Old Dec 30, 2005 | 11:02 PM
Default RE: What part of the ECM....
You could probably do away with the computer completely with some rewiring and rerouting of vacuum hoses.
Old Dec 31, 2005 | 02:51 PM
el_coqui's Avatar
Does the transmission use the computer?
Old Jan 9, 2006 | 08:47 PM
gmpartsguy's Avatar
The other thing you need to do is check your local emission laws. some state yo have to have all emission components.
Old Jan 22, 2006 | 01:11 AM
Dancj2's Avatar
ORIGINAL: gmpartsguy
Let me tell you what, we all are going to check all local laws before doing any cool mods to the car.
lol
Dannie
Old Jan 22, 2006 | 09:40 PM
Sleeper91's Avatar
take it all out if you have a carb, except the map sensor
you can take out the brake booster hose if you want , but you'll crash pulling out of your driveway
haha
Old Mar 10, 2006 | 11:15 AM
Cody's Avatar
I have a 86 camaro thats non electric that i just put a 355 H.O. Stroker in and had the same wireing mess, and what i did was trace the wires back to where they originated from looked if the were connected any where and if not i pulled them out
Old Mar 12, 2006 | 10:47 PM
mattvogt's Avatar
big problem here. cant just get rid of part of the ecm. if you do that then the car wont run correctly. either deal with it(not a good choice) or do away with it.
Im facing these options now (actually in the near future)
Old Apr 4, 2006 | 04:35 PM
shnormo's Avatar
Trans needs it even if it is a manual.
Ecidemon
Sep 3, 2012 04:16 AM
BlueKitsune
Nov 20, 2008 03:44 PM
IROCNeeveeZ28
Jan 20, 2008 01:10 PM
evansrs
82-92 V6 Tech
Oct 10, 2007 08:53 PM
