Car Wont Start
Old Sep 4, 2007 | 07:23 AM
1985IrocZ's Avatar
Default Car Wont Start
My car is a 1985 Iroc Camaro with the 5.0 Tuned Port Injection. I know I am getting spark and the timing is right, but my problem is that im not getting fuel. What confuses me about the fuel part is that whenever i spray starting fluid in it, it wont even start on that. Also whenever I push down on the schrader valve, no gas squirts out. What could possibly be wrong with my car, low fuel pressure? Any other ideas?
Old Sep 23, 2007 | 10:08 PM
EddieTheRipper's Avatar
Default RE: Car Wont Start
Wow, It wont even fire on a snort of ether? strange. but anyways id be checkin if the fuel pump kicks in when the keys turned on.. if not check the relay or even replace the pumpand change the filter... but as for the starting fluid.. ive never seen a engine with spark not bark on a shot of that stuff..
Old Sep 30, 2007 | 09:58 AM
Dougs1990rs's Avatar
check your control module in the distrubitor. also check your oil pressure switch. gm's little safety device little or no oil pressure signal no fuel pump
Slundy12
Dec 11, 2011 07:57 PM
Luz Hernandez
Feb 26, 2011 09:17 PM
mjstempky
Feb 19, 2011 01:17 PM
jpkz94
Jan 21, 2011 01:47 PM
89Rally
May 3, 2007 01:49 AM
