cooling fan problem
Old Aug 6, 2007 | 03:39 PM
mr porky's Avatar
Default cooling fan problem
Help ! New to this site and just aquired a '92 RS Camaro. The cooling fan does not seem to work at all, it would appear to be an electronically controlled fan but is not triggering. Is this a common problem? Where should I be looking for sensors etc? I have a manual but it does not give any help in this area.
Would it be OK to just splice the wires and fit a switch in the dash?
Any help greatly received...
Old Aug 31, 2007 | 01:35 PM
MaiNpHraMe's Avatar
Default RE: cooling fan problem
replace your relays.
Old Aug 31, 2007 | 11:59 PM
sewerrat's Avatar
Disconnecting the plug going to the cooling fan and connect to 12v source and a ground to check if your fan actually works. Try to repair the system so it works as it was intended to do. That way you may not have to run a toggle switch. If all else fails then wiring adashswitch isn't to hard.
Old Sep 15, 2007 | 06:27 PM
91bluers's Avatar
i agree check your relays and try to get it working right then resort to a manual fan be sure to check the wiring frm the fan to be sure that its not fried or cut any where
Chevy101
Jun 29, 2010 07:59 AM
gville4life
Apr 7, 2010 11:27 AM
heath3800
Jan 9, 2010 10:59 AM
02blackonblack
Aug 16, 2007 04:01 PM
92camsilboat
Apr 30, 2006 10:11 PM
