ideal rpm'adge for quick off the line
Old Oct 2, 2005 | 05:28 AM
Don Hog's Avatar
Default ideal rpm'adge for quick off the line
what would be the ideal rpms to get up to for a fast off the line start ....before you burn or spinout the wheels...???
in a 6 sp 95 Z lt1
Old Oct 2, 2005 | 12:09 PM
Default RE: ideal rpm'adge for quick off the line
To many factors. Things like tires, suspension mods and track conditions all come into play. Try s slipping the clutch out rather fast from 2000 rpm and see what happens.
Old Oct 2, 2005 | 11:14 PM
This is all trial and error till u get it right. Each car is different, each track is different and is constantly changing. The more runs u get under your belt the better u going to get at it, and the better u will be able to cope with changes. Drag strip racing is a little more involved than than just following a formula. The best part is that u can't BS about the results, can't argue with time slips. Basically u want as little wheel spin as possible without causing the engine to bog.
Dcapper81
Apr 22, 2012 11:21 PM
1998camarossclone
Oct 4, 2010 10:14 AM
Red93Camaro
Dec 13, 2007 02:12 PM
91 RS
Feb 28, 2007 11:21 PM
CamaroLOC
Dec 23, 2005 09:30 PM
