Engine Light continually turns on...
Old Apr 27, 2007 | 10:17 PM
foxtrot51's Avatar
Default Engine Light continually turns on...
For some reason every time I take my Camaro up to 55 and over and release the gas pedal the service engine light turns on. Now I have tried to clean the EGR valve twice and the problem reoccurs, I now have a feeling that the transmission is having trouble shifting from third to second gear. I don't mind etting a new EGR valve but I would like to avoid any pointless expenses. Any help would be greatly appreciated.
Old Apr 27, 2007 | 10:37 PM
Default RE: Engine Light continually turns on...
The check engine lite tells you what you should do. Get the car scanned and see what the complaint is about and take it from there. Check for retained codes if the lite is off at the time.
Old May 2, 2007 | 11:28 PM
purpl96's Avatar
It could be something as simple as a bad oxygen sensor in your exhaust because Camaros are notorious for having the oxygen sensors go bad in them.
Old May 3, 2007 | 09:33 AM
usarmyrangrs's Avatar
Given it's an OBDII equipped vehicle, there are literally over 1,000 circumstances that the MIL will be illuminated. It's pretty much guesswork until it's scanned :-P
Rent
Apr 22, 2013 11:08 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
gotalcoholmanup
Mar 1, 2008 07:00 PM
rambo619
Feb 15, 2007 09:12 PM
94v6green
Oct 12, 2006 12:15 AM
