More Power
Old Sep 10, 2005 | 05:48 AM
Charles_M's Avatar
Default More Power
I was wondering what do i need to get more horses out of my car, cuz at the moment i think it is only running at 160hp and that really sucks...i am looking for anything from preformance chips to superchargers. thanks
Old Sep 11, 2005 | 12:49 AM
Default RE: More Power
How much power do you want? How much money are you willing to spend?
Old Sep 11, 2005 | 05:57 AM
Charles_M's Avatar
umm...well i am looking to get up above 200hp possible 300 w/o swapin out engines...and really money i can work around in a reasonable sense, nothin like 1000 bucks for a chip or things like that...but what ever you have to offer i will look at.
Old Sep 11, 2005 | 12:46 PM
What year & what engine does you car have?
Old Sep 11, 2005 | 06:58 PM
Charles_M's Avatar
its a 94 v6 3.4 liter
Old Sep 12, 2005 | 12:22 AM
The problem you have is that the engine is comparatively small and there aren't too many things you can do to get a lot of power without spending a good deal of money. The most cost efficient things you can do is to put in a cold air intake and a cat back exhaust sytem. Between the two you should get about 20 HP.
After these two mods things start to get more expansive and give comparatively less for your money.
In order of bang per dollar:
1) Get the computer reprogrammed for another 10 HP.
2) Put in a hotter cam (not too radical) and reprogram computer again
3) Upgrade to porcupine heads and manifold from a 3400 model used on W cars. May require some fitting, but I am not sure as I haven't tried these heads on a Camaro block, but they do fit on a W car block, which is about the same. You will need special lenght pushrods. Reprogram computer again.
4) Install headers
5) Add a nitrous kit
6) Add a supercharger, if you can find one for a 60 deg 6 cyl
7) Add a turbocharger. Try adapting the one used for the 1990 Pontiac McLaren W car( Turbo Grand Prix). This really puts out the ponys if tuned right, feels like an LT1 witha a strong bottom end, except that the bottom of the engine does not like it when you use some serios boost. Pounds the hell out of the bearings, and oil pressure needs to watched. ( You will probably need the whole car in order to get all the pieces).
Pete
Old Sep 12, 2005 | 01:12 AM
Charles_M's Avatar
thanks man...now the thing is, where can i get a good cold ain intake and a cat back exhaust system?
MaxTheKiing
Aug 23, 2010 03:21 AM
rbeard
Aug 9, 2009 12:11 AM
dkblind87
Jul 27, 2009 05:35 PM
IBADRIDE
Jul 13, 2006 01:44 AM
