Squeek from shocks when they are cold
Old Apr 8, 2007 | 12:40 AM
CO99Z28's Avatar
Default Squeek from shocks when they are cold
When the weather is cold out there is a squeek from the rear shocks or something back there...
Anyone else have this problem? I have a 99 Z28 and it bugs the hell out of me, will getting the shocks replaced take away the squeek?
You can get out of the car and push up and down on the rear and hear the noise.
Thanks for any help with this.
Old Apr 8, 2007 | 01:15 AM
ryan88z's Avatar
Default RE: Squeek from shocks when they are cold
Damm dude I got a 95 z and same here in the cold .
Old Apr 8, 2007 | 02:14 AM
Saint_Ali's Avatar
yeah i have a 93z and i hear the same thing, i replaced the original shocks with bilstein but i can still hear it when going over speed bumps, i dont think its just in cold though
Old Apr 9, 2007 | 02:14 PM
NomadicZ28's Avatar
I have a 1996 Z28 and everytime I go over railroad tracks slow (or any over any bump) I hear that noise. I figured it was just mine.
Old Apr 9, 2007 | 04:43 PM
Are you sure it is the shocks? If you have worn bushings, or poly bushingsthat need to belubed, they will squeak.
Old Apr 9, 2007 | 11:31 PM
CO99Z28's Avatar
Hey Pete.
Today it was 70andIwas out cruising withthe top down enjoying the weather andthere wasno squeeking what so ever.
Yesterday it was 30 and snowing and man was it squeeky.
Stupid problem to have but as long as its warm out then it is not a problem.
Old Apr 10, 2007 | 12:44 AM
Well, the bushings can shrink and expand with the weather, but the shocks do that also. May want to shoot a little WD40 on the shock shaft & see if it stops, if it doesn't then it is probably the shock mounts or the suspension bushings. Had a car that would squeakduring dry spells and quiet down on rainy days. Turned the rubber bushings were worn and moving about the mounts and making noise. When itrained they would get lubed by the water and stay quiet. Squeaks and rattles are hard to locate, and takes a lot of trial and error to find them.
Old May 22, 2007 | 09:54 AM
95POLOVERT's Avatar
I got a 95 with the same thing, i think its the rear of the car twisting, probably bushings or shock mounts not shocks
Old Nov 29, 2007 | 08:40 AM
Puck90a's Avatar
Dominos Puck
New Formula! Now with 10% more Win!
I know this is an older thread, but I have this same prob on my 95 Z.
Yep - when it gets cold (which it has just started to in Louisiana) the rear squeaks and groans big time. When it rains or is humid, I don't hear a peep.
It's gotta be the bushings for sure. I've heard the sway bar bushings are fairly easy to replace, but what about the other ones? How many are there exactly? Is there a kit that includes all the bushings you need for the whole job? Could I replace all of them myself with basic tools?
Mrjshua
Jul 30, 2011 03:38 AM
baseballer91
Apr 11, 2008 11:23 PM
purpl96
May 23, 2007 08:55 PM
Rs Camaro Kid
Jan 17, 2007 01:42 AM
carguylt1
Oct 29, 2006 12:25 PM
