rear axle lineup?
Old Apr 7, 2007 | 10:23 AM
wilbglc's Avatar
Default rear axle lineup?
I have a 1967 camaro. I bought a new rear 10 bolt 8.5" axle(complete and correct) and need to install it. Does anyone know how to line up the rear housing spring mounts to the car to make the dimensions correct? I have a build manual but the information is vague. Thanks.
Old Apr 7, 2007 | 04:39 PM
Default RE: rear axle lineup?
Does the axle have spring perches installed or do you have to put in your own?
Old Apr 7, 2007 | 09:24 PM
wilbglc's Avatar
Spring perches are there. Everything is there. Thanks.
Old Apr 9, 2007 | 06:58 PM
jonnyNITRO's Avatar
When you say new, is it made for the year car you have? If so, it should just bolt right up. The driveshaft angle should be fine ... unless you changed something else in the driveline.
Old Apr 17, 2007 | 03:01 PM
1969 SS's Avatar
total bolt in, no lining up should, or even could be, necessary
Old Apr 19, 2007 | 12:08 AM
firebird69racer's Avatar
depends on what the 8.5" came out of.
the 8.5" didnt come in the Camaro until 71 or 72 and were not the same width
if it came from a Nova 72-75 then it will bolt right in
Old Apr 19, 2007 | 02:59 AM
mikebrow74's Avatar
There is also a difference between mono leaf and multi leaf spring perches. The later Camaro rear ends are wider axle to axle too.
Old Apr 19, 2007 | 04:08 PM
1969 SS's Avatar
ORIGINAL: firebird69racer
I was assuming his reareand came out of a similar car. also the Nova thing works from 68 to 74
Old Apr 21, 2007 | 01:23 AM
ORIGINAL: 1969 SS
68-75 Nova fit, I just listed 72-75 as thats the years for the 8.5"
also
Apollo 73-75
Omega 73-75
Ventura 71-75
are 8.5" that interchange
Old Apr 21, 2007 | 05:27 AM
1969 SS's Avatar
also
Apollo 73-75
Omega 73-75
Ventura 71-75
[/quote]
oops...very good...carry on
