removing swirl marks.
Old Mar 16, 2007 | 04:40 AM
kyleb's Avatar
Default removing swirl marks.
is getting a new paint job the only way to removing swirl marks?
wet sanding will help? rubbing compound worked for a little while but now it looks as if it has worn off.
thank you!
Old Mar 20, 2007 | 01:09 PM
350rs's Avatar
March 2008 ROTM
Default RE: removing swirl marks.
there is a swirl remover i saw at a auto parts store. i have no idea how well it does or dosent work though...
Old Mar 22, 2007 | 10:17 PM
tommynos's Avatar
July 2007 ROTM
they can be removed..i found a polish off the back off a detailing truck that polished the wetsand out and left no swirls on my black gn....check with those detail supply trucks or a paint and body supply store...
Old Mar 23, 2007 | 05:32 AM
MadMikeZ28's Avatar
Compounds will bring back a shine, remove oxidation and paint. But it will take away from the glos and lustre. To finish you need a product like 3M's finness it to remove the swirls. A auto paint store would have it. Some Crapa's also cary automotive paint and polishing supplies but places like pep boys, autozone, csk. they do not
Old Apr 21, 2007 | 07:43 PM
The Banks's Avatar
Try claybarring and then waxing. For specific areas you could try Nu Finish or something like it.
Old Apr 23, 2007 | 01:02 PM
Swirl marks are more a result of improper washing and care than anything, although an inexperienced person using a buffer will cause them as well. When washing, use the two bucket method (one for soap and the other to rinse your mit. Only use micro-fiber cloth on the paint and when waxing or drying always use straight back and forth motions and not circles.
Old Apr 23, 2007 | 08:30 PM
bluovlh8er's Avatar
x2 for jd, to get them out use a buffer and GOOD rubbing/polishing/ compound.
Old Apr 23, 2007 | 09:32 PM
The Banks's Avatar
Hm, I've never thought about using two buckets before. I'm going to have to try that.
mikes68
Apr 8, 2012 08:12 PM
JJ_77
Oct 23, 2008 05:07 PM
stovebolt_six
Apr 2, 2007 01:23 PM
KJK
Mar 29, 2006 10:13 PM
