What Stall Convertor Speed?
Old Aug 20, 2005 | 04:04 PM
bjames5's Avatar
Default What Stall Convertor Speed?
I own a 93 Camaro Z28 with the 4L60E. Since I have added all the upgrades I have went through three transimissions. I am on my fourth one right now. Can anyone tell me if changing my stall would help and if so which speed? I have also seen some that were lock up or non lock up. Which would be best?
[IMG]local://upfiles/1251/3D99FFB684E743E0973B0182C2F2B70E.jpg[/IMG]
Old Aug 21, 2005 | 02:38 AM
Default RE: What Stall Convertor Speed?
Good looking car, congrats.
Before thinking about high stall converter, you should be thinking about beefing up your tranny. This transmission is marginal with the LT1, and if it is pushed hard it won't last long. There are many companies that that beef these things up so that they can take the pounding.
A loose converter is not gping to help because by the time the transmission shifts it will be all revved up and just as tight as the stock unit. In addition, bacause of the additional slippagr, the transmission will tend to run run hot in traffic and burn itself out even faster.
Being that you have overdrive, you could try lower rear end gears, something around 4.11, this will take some of the load off the tranny and probably make your car quicker. Of course, now you most likely need drag slicks, and hopefully your rear end will hold toghether.
Old Aug 22, 2005 | 10:10 PM
bjames5's Avatar
Thanks for the input. Will take your advice and hold off a little before deciding anything.
Old Aug 31, 2005 | 10:08 PM
TB561's Avatar
get a 2500 stall converter
get higher performance bands, shift kit, tranny cooler, sun shell, clutches and get it built good. Sonnax has a nice 15% wider kevlar band. They also make nice transmission valves. Reybestos has good performance clutches.
Filthy McNasty
Mar 8, 2011 06:46 PM
myTreadZz
Nov 2, 2007 09:12 AM
CamaroKid81
Feb 24, 2007 02:19 AM
ScottD
Sep 13, 2006 02:04 PM
