LS-1
Old Aug 5, 2005 | 02:45 PM
deang423's Avatar
Default LS-1
Would an ls-1 motor work in a 96 z? Would it take a new PC or other hardware? Direct bolt in and use existing hoses, switches and sensors?
thanks
Old Aug 5, 2005 | 07:14 PM
Default RE: LS-1
You will need the entire wiring harness and ECU, also the radiator and all accesories. The swap can be done but honestly it might be cheaper/easier to just go buy an LS1 car. Unless you can get a deal the motor and trans will run at least $4-5000, and no the LT1 trans is not the same (at least the 6 speed, the 4l60E might bolt up not 100% on that)
