A/C Problems
Old Jul 24, 2005 | 04:52 PM
runedawg's Avatar
Default A/C Problems
Its not a camaro so I wasnt sure where to post so I matched the year.
Its a 78 Caprice Classic with no mods. When you switch the A/C on the compressor cluth doesn't kick on, But if you run a hot jumper to it the clutch engages. The Compressor isnt leaking nor iss everything else. Is there a relay or switch that causes the clutch to kick in when switched on inside the car? What else could be wrong?
Old Aug 14, 2005 | 07:01 PM
Default RE: A/C Problems
There is a safety switch that prevents the compressor clutch from kicking in if the pressure in the AC system is too low. Get a freeze12 retrofit kit and some freeze12 and recharge the system. Freon is too hard tofind these days.
Old Aug 15, 2005 | 02:30 PM
runedawg's Avatar
I got it figured out. It was low on juice and the compressor clutch cut out swith was bad.
mp734
Nov 6, 2013 11:54 AM
nmallory56
Jul 21, 2009 03:34 PM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
Nov 11, 2007 11:56 AM
