Sbc 400
Old Sep 7, 2010 | 10:59 PM
  #21
That "something else 010" would mean the main journals were also turned down.
J 30 72 date on the block is 10-30-1972. A-L = 1-12.
Old Sep 8, 2010 | 06:10 AM
  #22
mainejohn's Avatar
thanks for all the help, you guys have been great. so will this 400 with the stock heads make more power then my 350 with stock heads? if not then its probally a waste of money!!!
Old Sep 8, 2010 | 08:41 AM
  #23
Yes it will, and oodles of torque too. Why do you think 383 and up stroker motors are so popular? They use a 400 crank, and are the next best thing to having what you already have.
Old Sep 8, 2010 | 10:29 AM
  #24
Your 400 can be a monster for not alot of cash. Get the rebuild done and down the road a set of heads will turn it into a beast. The biggest advantage that a 400 has over a 350 is the 4.25 bore. 350s are 4.00, this allwos for the intake valve to be unshrouded and let the heads suck more air in.
Old Sep 8, 2010 | 11:22 AM
  #25
mainejohn's Avatar
should i go with solid lifters or hydraulic lifters?
Old Sep 9, 2010 | 09:04 PM
  #26
Y2K's Avatar
Y2K
I like solids but I'm old school.
Really these days there are so many good hydraulic cams it's the way to go,no muss no fuss,solids need adjusting on a regular basis if you run hard much.
Solids are pretty much are old tech like points ignitions,still gets the job done but there are better options
Old Sep 10, 2010 | 12:19 AM
  #27
Osmiumfoot's Avatar
Smile
I think you mean a 4.125 bore.
Old Sep 10, 2010 | 04:49 AM
  #28
Yeah your right. Lets not make it a BB here. Just made a quick post on lunch. Brain was workinig faster than my fingers,
Old Sep 10, 2010 | 12:58 PM
  #29
mainejohn's Avatar
i just brought the block over to the machine shop to get it magnafluxed and they asked if i had the end caps? i said no it didn't come with them. so he said i might as well look for a new block because each engine has its own end caps and they are not all interchangeable. he said i get new ones and have it lined bored but it would cost way more then the motor is worth!! so is there any thruth to this?
Old Sep 10, 2010 | 01:05 PM
  #30
Yes. All the main caps are torqued down to the block, and then it gets align bored. If any are m.i.a., you have to do what the guy at the machine shop is saying. Sometimes a block needs to be align bored anyway just because of wear or age. Did he tell you how much it would cost to do, if you were to find some caps?
