350 swap project
Old May 23, 2010 | 04:32 PM
  #21
Jr. Mechanic's Avatar
August 2009 ROTM
I've got a set of heads for sale but I believe they're pretty much just as worthless as yours.
Old May 28, 2010 | 04:16 PM
  #22
endo's Avatar
Default update
ok im at a point where i need to make a decision of what i want my engine to do before i can start getting some work done.
i want low end torque i want my engine to top out at about 5,500 rpm. i started looking for a cam that will fit what i want to do.
also i am going with a carb set up for sure.
i also have a thread for picking some heads. would 327 double hump heads do what i want.
Recondidtioned Heads from a 327 Double Pumper ...pre 1969
Also included are the Intake Manifold and the oil pan, $250.00
i have an email into this guy to find out what the cast # is on these.
here are some cams i found that i thought would fit what i want to do.
link 1
Link 2
Link 3
Link 4
let me know what you guys think.
Old Jun 25, 2010 | 11:36 PM
  #23
endo's Avatar
Update
found heads and a cam.
may not keep the heads just depends if i can find a buyer and some good aftermarket heads.
heads
casting # 3927186
date code is H278 - August 27, 1968
intake 2.02" exhaust 1.6" chamber CC 63.305
a little porting done to them.
stainless 2.02 in manley intake valves
metal viton seals
3/8 rocker stud
magnaflux by the shop that did the work
ended up costing $400 but still a good deal.
New stuff
Cam
Comp Cam
Part #: 12-210-2
Grind #: 268H
RPM-Range:1500 to 5500
Lobe-Center Angle: 110
Duration: Intake 268 Exhaust 268
Valve Lift: .454
melling oil pump m-55hv
Cloyes Gear C-3023X Double Roller Chain
Old Aug 28, 2010 | 09:16 AM
  #24
endo's Avatar
Update
here are some pics. taped and before and after paint.
what do you all think about yellow with chrome.
water pump
Old Aug 31, 2010 | 10:54 PM
  #25
endo's Avatar
last coat of paint went on today. also ordered some more stuff sunday.
check out the pics
Old Sep 1, 2010 | 04:53 PM
  #26
ScottD's Avatar
What color is that? School bus or Big bird! JFC I used to think you were cool.....
Seriously, it looks like your making progress. Its a very rewarding experience. Just make DAMN sure up cover up EVERY hole, open port and opening when its all assembled.....little nuts find their way into distributor holes way to easily....
dont ask.
Old Sep 1, 2010 | 08:58 PM
  #27
endo's Avatar
daytona yellow. it is a great yellow in person. yep i already dont keep anything little around my block and heads because i dont want any chance of breaking anything.
i got a few things to buy still but i think that i will be able to start putting something together this weekend.
Old Sep 2, 2010 | 09:47 PM
  #28
endo's Avatar
My March Performance Serpentine Kit got to my house today.
Old Sep 11, 2010 | 09:51 PM
  #29
endo's Avatar
Update !!!!!!!!
I dont have pictures for all i have done as it was 9:30 when i finished and dark so the rest of the pics will come tomorrow.
got the crank installed. i plastigauged to double check what the machine shop did. it all looked good.
installed rings on the pistons. very easy yet frustrating at the same time.
got all 8 pistons installed just need to torque them all down tomorrow.
Old Sep 12, 2010 | 05:10 PM
  #30
endo's Avatar
Update !!!!!
pistons installed
And pistons removed. 3 pistons had bent a oil ring. I removed all of the pistons because turning the crank was very difficult.
then the pistons installed again
timing chain
Lifters
