4 bolt main torque down?
Old Nov 19, 2009 | 04:49 PM
I think (hope) you meant under-sized?
Are you going to gage the bearings? You may need the .001 or .0006 bearing if there is some journal wear. Or has the crank been machined?
Old Nov 19, 2009 | 05:06 PM
so far as i can tell its all new. yes under. from i have read they used the undersize bearings to get exact clearance in the factory. talked to a few dealer shops i get parts from and cant get the factory kits for em. tried some places like ecklers too. i dont know what to think all the clearances are good so it could be a block that got sent back and was remaned but seems like it would have a vin on it then. still has the bar codes sticker on it. dont know if i can read em though.
Old Nov 19, 2009 | 05:32 PM
i hope it all works right. if not ill have the motor out of the car and am thinkin about gettin punched out to a 383 once its out but i should have a few yrs before i want more power bad enough to change motors again.
Jville_hot_skate
Dec 6, 2008 10:34 PM
95z281LE
Feb 27, 2008 10:23 PM
gozzy341
Nov 4, 2007 08:52 PM
JYori
Nov 26, 2006 10:25 PM
mcge383
Nov 10, 2006 11:53 AM
