Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
Nitrous/Methanol injection
Old 02-23-2015, 07:53 AM
SgtMarshal's Avatar
Default Nitrous/Methanol injection
I've been considering a nitrous methanol injection setup on a possible 4th gen Camaro build. I have a set of heads from the factory that will bolt on to a v6 L36 that have injector bungs in them. on the L36 Camaro's the injector bungs are in the intake manifold, so installation of the heads would provide a good setup for a direct port nitrous injection.
When I was looking at the Nitrous Outlet Pirana nozzles, it looked like they already were plumbed for 2 things to be injected, and since I dont need to inject gas with the nitrous I thought they would be perfect to setup a combination nitrous with water/methanol.
Any thoughts or input? Has anyone done this before?
Old 01-07-2017, 06:42 PM
cbr600rx7's Avatar
You would be better off running a stand alone fuel cell For the fuel side of the nitrous nozzle. This would allow you to run a higher octane fuel (105-113 octane) and effectively run a larger shot.
i would not inject nitrous and water/meth into the same space. Nitrous is extreamly cold and you need the water/meth to atomizer or your going to have a bad time.
Nathan2001Z/rs
11-05-2011 12:17 AM
snapper08
03-31-2008 09:31 PM
70_boosted
07-07-2007 10:46 PM
rs305
01-31-2007 06:41 PM
94CamaroSFI
12-06-2006 09:36 PM
Quick Reply: Nitrous/Methanol injection
