Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
STS TURBO
Old Oct 15, 2007 | 06:50 PM
cbr600rx7's Avatar
Default STS TURBO
Hey every one. This is for any one thats ran the STS rear turbo system. Is there any one that ahas positive or negitive to say about the system or tuning with it. I would expect a little more lag than a normal turbo in the engine bay due to the longer pips but tuning on them doesnt look to bad. Any input is welcome.
Old Oct 15, 2007 | 09:34 PM
Default RE: STS TURBO
http://www.chevyhiperformance.com/te...rbo/index.html
However, I really have my doubts about this one. If it works as well as they say, why are the factories going through the trouble of mounting the turbo as close to the engine as possible.
Old Oct 24, 2007 | 11:28 AM
BigNic's Avatar
4' 11" 117 lbs of fury!
honestly bro exaught pips are designed to reduce the pressure and heat at which exaught fuems flow out of your car since you need that pressure to spin the turbo whats the bloody point of putting it in back it just makes it less affective
Old Oct 26, 2007 | 06:14 PM
cbr600rx7's Avatar
Not true. Becase its so far back from the engine you dont have to worry about the heat from the turbo. Also the turbo acts as a muffler and only has about 2 feet of exhaust after it so there is no back pressure. Also the long pipe that runs back to the engine acts as a small Intercooler. Its easy to install and makes good every day power.
Old Nov 7, 2007 | 11:22 AM
LT1RUNNER's Avatar
But what are the advantages over an engine mounted turbo? Cost? Driveability?
Old Nov 7, 2007 | 02:04 PM
02StanGT's Avatar
ORIGINAL: BigNic
If that's the case, then car companies wouldn't put mufflers on cars, and would run open exhaust pipes through the hood...
Old Nov 7, 2007 | 07:30 PM
1990CamaroRS's Avatar
Fancy Sparkle
ORIGINAL: LT1RUNNER
gas mileage will be slightly better because the turbo's not going to be spooling like mad all the time. it's almost a better setup for a BB that you want to look like a sleeper. a BB isn't going to have trouble spooling a rear mount because of the amount of air flow out the exhaust. it's also better for racing apps (like road racing, not drag) because of the delay you get once the gas is applied. you don't get the hammer of G0D surge right off the bat, but that means better traction out of the corner
Old Dec 11, 2007 | 06:58 PM
cbr600rx7's Avatar
I know this is old but for the lag part.
"I thought I had a fast ride before I put the turbo system on, and I was right, but now! The car really screams!
I had second thoughts after I ordered the system. I thought, "There is no way this thing can be that good, the lag is going to be terrible!" I had to eat my words the first time I drove my T/A! The only thing I could think was "Holy *&#%" I had to lift off the throttle, it scared me that bad. What lag!?! None. The boost hits, and it hits HARD!
Cobras don't stand a snowballs chance in hell. Yes it's that good. And it's worth the money. The only thing I wished I'd done different, ORDERED THE KIT ALOT SOONER!!!"
Shawn Coleman, White Sulphur Springs - West Virginia
Old Dec 11, 2007 | 08:48 PM
ninetysixyenko's Avatar
the lag shouldne be THAT bad, maybe max of .5sec longer, at max, and for street racing, that shouldnt matter to much, and you can just brake boost to get ur pressure back up anyway.. i always thought one of those would be good for like a truck, not something to be fast, but something you want to surprise people and have umph to it. only thing i dont like is it acting like a muffler(want teh loudness), and that it would be hard on a "true" dual exhaust(not just split after muffler)
Old Dec 12, 2007 | 04:48 AM
cbr600rx7's Avatar
True duel = Twin turbo.
