1969 automatic to 5 speed conversion question on pedal assembly
Old 05-30-2016, 09:21 PM
69camarolover's Avatar
Default 1969 automatic to 5 speed conversion question on pedal assembly
Does anyone know if the brake pedal mounting bracket on an original automatic car will work for mounting the clutch/brake assembly for manual transmission?
Thanks!
Old 05-31-2016, 01:17 AM
The pedal support bracket is the same for automatic or manual.
Old 05-31-2016, 05:47 AM
Camaro 69, thank you for the info. I was hoping that was the case.
Old 05-31-2016, 08:24 AM
Everett#2390's Avatar
And check firewall under master cylinder for a panel held on with one screw as this is the hole for the pedal rod along with bellows.
Old 05-31-2016, 07:57 PM
Thanks Everett. I'll check that. Is it screwed on from the interior side?
Old 05-31-2016, 08:02 PM
Engine side
Old 05-31-2016, 08:05 PM
10-4, thanks!
Gen1admirer
02-16-2013 11:36 PM
tattoo400
07-15-2012 01:52 PM
69SS427
04-15-2011 08:10 PM
jasunf
05-03-2010 10:46 AM
Franksflying1
09-22-2009 10:27 AM
Quick Reply: 1969 automatic to 5 speed conversion question on pedal assembly
