repair help, please!
dealer told me i need a new clutch master and slave cylinder... would it be stupid to not change clutch while doing that repair? the whine is not too bad right now; how long can i last with the bad cylinders now?
how easy is it to change an O2 sensor by myself?
thanks!
thanks!
Your post is confusing, A failing Master/slave cylinder will not cause a whine. It will cause a hard to shift and hard to get into gear issue. Whine would be from the Release bearing.
02 sensor on the passenger side can be a pita. the clutch cylinders should not effect the clutch. once the cylinder goes you will not be able to use it though. usually gradually goes.
Ok, u need to not be lazy and go out and look at ur slave cylinder, if its bad ul see a leak. Your master cylinder could make a whine/squeeking noise and may be bad even without an external leak.. If u can go WOT and don't feel the clutch slip then u don't need a new clutch.
