LT1/LT4 Tech 1993-1997
Power steering pulley
Old 09-11-2011, 09:57 PM
timmyz28's Avatar
Default Power steering pulley
Does anyone know where I can buy a replacement power steering pulley for a good price? This belt squeal has been annoying me and I want to take care of it.
Old 09-12-2011, 08:50 AM
heres the pulley. are you sure its not a worn out tensioner. Pulley, 93-97 V8 5.7L LT1 Camaro/Firebird Power Steering Pulley Used
Old 09-12-2011, 12:08 PM
timmyz28's Avatar
Belt is brand new, tensioner is brand new. I have a stethoscope and its coming from the power steering.
Old 09-12-2011, 12:46 PM
Psycho's Avatar
You would be ahead to replace the whole pump then. The wheel must be pressed off. The pump is held on by 2 bolts. Easy replacement. I believe it is easier to remove and replace the oil lines when it is loose from the mount also. Been there done that.
Old 09-12-2011, 06:13 PM
timmyz28's Avatar
I don't want to do the pump if I have don't have to, and I have the puller for the pulley anyways.
Old 09-13-2011, 01:11 AM
im on my third rebuilt pump and its goin. any oil at all on the pulley. could try cleaning it with acitone and hit it with some emery. if the pump is failing it may be putting to much pressure on the belt. does it do it all the time or only when on hard turns.
Old 09-13-2011, 08:18 AM
I'm curious why you think replacing the p.s. pulley is going to get rid of your belt squeal. Is the pulley bent? What kind of serpentine belt are you using, AutoZone blue-light specials?
I stick with the Goodyear Gatorback belts because they're designed to not squeal, and I've never had belt squeal with one. They're worth the extra money spent.
Old 09-13-2011, 12:06 PM
timmyz28's Avatar
It does it all the time, and its a belt squeal, not a power steering whine. And I buy my belts from Advanced. For the past year or so, something has been chewing up the belts. I've had to replace 3 in the past year. Before that, I put a belt on when I first bought the car and it lasted like 2-3 years.
Old 09-13-2011, 12:41 PM
A belt should last well more than 2-3 years even. Something chewing up the belt is a pulley alignment issue. I'd get under there as best as possible with a straight edge and see what looks out of whack. You replaced the tensioner, if that was wobbly it would have been a good reason for your eaten up belts. Or, have you been going through belts since the new tensioner?
Old 09-13-2011, 07:23 PM
timmyz28's Avatar
I got the new tensioner after the new belt and it hasn't chewed the belt up, but it still squeals. And I just noticed today, the power steering pulley does in fact have a little wobble to it. The bolts for the pump were tight, but I got a little more turn out of them. Started it back up and still has a little wobble, so now I have to see if it's the seat of the pulley on the shaft or the shaft is bent.
shane1617
05-22-2011 08:35 PM
JJs94Camaro
10-30-2010 11:03 PM
dto325
07-13-2009 11:11 AM
wowcow
09-19-2008 02:47 PM
busportygrl
82-92 V8 Tech
11-08-2007 02:49 PM
Quick Reply: Power steering pulley
