no oil presure
no oil presure
ok guy i need some help if you can. i lost all oil presure from my car and the valves started ticking so no oil getting up top right. well replace the oil pump today still doing if. is there something else that migh be the problem? thanks for any advice.
i was thinkin that but i replaced that with a builit aluiminum 1 about 2 years ago. and when i put the pump in i put the shaft up tried to turn it and it wouldn't, also no chunks of anything was in the oil pan.
there made of plastic, well some kind of composite. i used a aluminum aftermarket housing. http://www.herronperformance.com/sto...&productId=317
stock are like 50 bucks new GM Parts Direct: Your direct source for Genuine GM Parts
the plastic ones break and that lets it ride up till the gear doesnt reach the cam gear or the pump driveshaft disconnects. ive heard of the pin in the gear and/or the gear itself fail.
