Engine Sputtering need help!
OK this only happens under the following conditions:
- Engine is at normal operating temperature
- Car is in Drive or Reverse
This only started happening when the weather got cold out. In Neutral or Park the car is fine. It's only when there's a load on the engine.
I thought it was vacuum lines and found a vacuum leak so I fixed my lines. No check engine light is on. The RPM's go up and down when I'm at idle in drive at a red light. If anyone has some insight on what to check please let me know thanks!
Thanks guys. IAC is 1 year old. I don't mind spending the $30 for a new temp sensor since I didn't replace it when I replaced the water pump. I did seafoam my intake. I'll check the IAC..... just a pain to take it out lol.
baradonai
11-12-2010 10:54 PM
