-   LT1/LT4 Tech (https://camaroforums.com/forum/lt1-lt4-tech-9/)
-   -   Engine Sputtering need help! (https://camaroforums.com/forum/lt1-lt4-tech-9/engine-sputtering-need-help-79426/)
mrfreez 11-11-2015 08:39 PM
OK this only happens under the following conditions:
- Engine is at normal operating temperature
- Car is in Drive or Reverse
This only started happening when the weather got cold out. In Neutral or Park the car is fine. It's only when there's a load on the engine.
I thought it was vacuum lines and found a vacuum leak so I fixed my lines. No check engine light is on. The RPM's go up and down when I'm at idle in drive at a red light. If anyone has some insight on what to check please let me know thanks!
cardo 11-13-2015 12:27 AM
Check for codes. U can still have codes w/o the CEL illuminated. Always use diagnostics before buying parts.
craby 11-13-2015 06:32 AM
test the engine temp sensor at the front of the water pump. check iac (intake air control) sensor to see if its carbon'd up.
mrfreez 11-13-2015 01:29 PM
Thanks guys. IAC is 1 year old. I don't mind spending the $30 for a new temp sensor since I didn't replace it when I replaced the water pump. I did seafoam my intake. I'll check the IAC..... just a pain to take it out lol.
craby 11-13-2015 08:50 PM
you can test it with a ohm meter without taking it out. http://shbox.com/1/4th_gen_tech2.html#ect
craby 11-13-2015 08:54 PM
better test fuel pressure too. does it sould like a missing cylinder? maybe check all your plug wires and make sure one is not lose or damaged.
