LT1/LT4 Tech 1993-1997
converting to ls1 ignition?
Old 05-28-2014, 11:26 PM
jeffchairs's Avatar
Default converting to ls1 ignition?
Wandering if anyone has done it?is it dependable?
Old 05-29-2014, 10:15 AM
MKCoconuts's Avatar
Goodbye Opti! LT1 runs w/ coil packs and LS1 PCM. - LS1TECH
This is a long, but extremely informative thread on the subject. It's something I wanted to do to my car a while, but due to cost and what I want my vehicle for, I've decided it wasn't a necessity.
Old 05-29-2014, 10:38 AM
you can go with a efi system but like said very expensive. https://www.eficonnection.com/eficonnection/24xLT1.aspx
or you can go with a ltcc system for less. still not cheap. FULL THROTTLE SPEED - LT1 COIL CONVERSION
Old 05-29-2014, 11:59 AM
I was going to do the LTCC conversion on my Vette, I have already gathered up the necessary coils and wires. Now I'm selling the car, so there goes that plan! You still need to keep the optispark for spark timing, so you're not totally getting rid of everything that's problematic with the original setup. Our member Greenarrow has converted his over, you can shoot him a PM and ask if he thinks it's worth doing.
Old 05-29-2014, 01:14 PM
i have a ltcc in mine. seems to run a bit better. not that impressed.
Old 05-29-2014, 02:05 PM
So if you had an opti that was working perfectly fine, would you say the LTCC isn't worth the money doing just for the heck of it?
Even if you had a bad opti (bad optics or bearings), you would still need to fix that in addition to the LTCC changeover.
Old 05-29-2014, 08:14 PM
yep, not worth it
Old 05-29-2014, 10:15 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
It would cost as much to swap to a LS based motor to do a 24x swap.
Old 05-30-2014, 09:47 AM
jeffchairs's Avatar
I was wondering about the ltcc because I looked at jets I think it was for the msd oppti setup and it was like 1200 dollars.it seems like it is cheaper to go with the ltcc.have you had any ignition problems with the ltcc crabby or has it been more dependable then the standard oppti?
Old 05-30-2014, 11:51 AM
jeffchairs's Avatar
Oh yah wanted to ask so com do you live near Pasadena thought I might have seen your car before near my area
Quick Reply: converting to ls1 ignition?
