LT1/LT4 Tech 1993-1997
93 z-28 ABS sensor location
Old 04-19-2009, 02:36 PM
west 93 z28's Avatar
Default 93 z-28 ABS sensor location
Does anybody know where the abs sensors are on a 93 z-28. My abs light comes on after you drive about 100 yards
Old 04-19-2009, 06:26 PM
rondavis's Avatar
well it shoud be right off the the front hubs
Old 04-19-2009, 07:04 PM
threre sensors on/in all four hubs. check to see if you have any trouble codes stored in the system.
Old 04-19-2009, 10:13 PM
I have checked the codes and there is none. I checked the rear wheels and there is no sensors on them. I think there is one on the rear end but I don't know
Old 04-20-2009, 04:06 AM
ok is the abs light blinking or on steady? i must be wrong on the sensors at the rear. i could have sworn there were wires at the rear when i did a brake job a couple years ago, sorry bout that. have u changed either of the front hubs or done any work on the car reacently?
Old 04-20-2009, 12:48 PM
dm575's Avatar
Seem to recall from previous posts that the rear sensor is in the diff on pre 96ish models. My 97 has sensors on each rear wheel.
It was doing the same, error light on solid after few hundred yards. I reseated the front sensor connectors while changing the pads and it fixed the problem.
Old 04-20-2009, 05:04 PM
95slvrZ28's Avatar
If you have a pre 96 you can't have traction control thus the car has an individual wheel speed sensor for each of the front wheels and one for the rear wells that is located in the rear differential. The same goes for 96+ cars that do not have TCS. If your ABSinOp light is steadily on you may have a malfunctioning wheel speed sensor or one of the special "flexi" wire's for the fronts could be going/gone bad.
Old 04-20-2009, 05:22 PM
greenarrow's Avatar
September 2009 ROTM
usually if a wheel speed sensor goes, you'll have a SES for it also. Slvr, explain this "flexi" wire's for me. I've had a ABS inop light on for over a year and three dealerships have threw up their hands at it.
Old 04-20-2009, 07:22 PM
I think i found the one on the rearend it is at the top of the housing and fun to get to . i did not check the front because i was told there was none.
Old 04-21-2009, 01:32 AM
95slvrZ28's Avatar
As far as I know (meaning I haven't personally replaced nor delved into them) the front wheel speed sensors have a special connector/wire that is supposed to be more resistant to flexing (because the front wheels turn). On occation these can go bad (either the wire itself from the turning motion, or potentially the connector) and this can throw an ABS in OP light. I had that light for some time and it fixed itself *shrugs* so I never had to deal with it...
Quick Reply: 93 z-28 ABS sensor location
