LT1/LT4 Tech 1993-1997
1997 camaro 383 issues
Old 11-10-2016, 01:08 PM
richard23's Avatar
Default 1997 camaro 383 issues
I have a 1997 camaro with a 383 stroker. The car is cammed. Not sure what all else is done. The car sounds like it's misfiring when I first take off or if I am driving under 2,000 rpms. Also if I try to keep a consistent rpm it starts to jerk. But if I punch it the car runs normal. I just replaced O2 sensors, they seemed to help a little but didn't fix the problem. Btw the car has no cats just mufflers.
Old 11-10-2016, 07:40 PM
Y2K's Avatar
Y2K
Y2K is offline
The usual culprit is the Optispark dizzy on those LT1's.
Old 11-10-2016, 07:42 PM
richard23's Avatar
I just had the Optipark replaced about 6 months ago...
Old 11-10-2016, 09:30 PM
Y2K's Avatar
Y2K
Y2K is offline
Question
GM Performance or something else? I replaced the Opti on my '93 twice in 6 months. I didn't go with the GMP the second time because I was selling the car,had I kept I would have.
Old 11-11-2016, 04:52 AM
richard23's Avatar
It was with all GM parts. I only have like 1,000 miles on car since replaced. When the optispark went out on me the car was really hard to start and ran crappy. I know that's not the only symptom of optispark tho
Old 11-11-2016, 12:48 PM
MKCoconuts's Avatar
Check fuel pressure and make sure there are absolutely no exhaust leaks before or directly (6inches or so) after the O2 sensors. Was the car tuned for the cam and extra displacement?
Old 11-11-2016, 02:28 PM
richard23's Avatar
I actually had an exhaust leak and got that fixed. Thinking it was the problem, but it wasn't. I have not checked fuel pressure. My air to fuel ratio gauge looks good tho. All the work was done to the car before I bought it. I've had it for about three years.
Old 11-12-2016, 10:22 AM
Y2K's Avatar
Y2K
Y2K is offline
My LT1 ran like that for a while and it turned out to be a burnt plug wire on number 8,it would come and go as it shorted out or not. Seemed to not do it when I ran it hard and when I wasn't it would act all nutty .I guess there was enough vibration when I hammered on it to keep the shorting out to a minimum. Eventually it got worse and we found the issue.
Old 11-12-2016, 12:17 PM
has it been tuned? if not get it done, if so by who? tune may be going bad
Old 11-12-2016, 12:20 PM
also test your engine temp sensor, its at the front of the waterpump. http://shbox.com/1/4th_gen_tech2.html#ect had one go on a truck and it would only run half way right at wot. tested it and it showed -40 degrees. it was getting way too much fuel.
Quick Reply: 1997 camaro 383 issues
