Prestone Flush Kit Install Guide- LS1 engine Camaro
Since the information is not easily found, here's a great little guide for you all installing a Prestone flush kit in your LS1/LS2 engine:
A = Water pump outlet to heater core, 5/8".
B = Water pump inlet from heater core, 3/4". <-- hose where the tee goes, in the straightest area you can use!
C = Water pump inlet / thermostat housing (in to engine from radiator), 1-1/2".
N = Water pump outlet (out to radiator, from engine), 1-1/4".
My install:
Clearly Prestone's guidance SUCKS! “Hose #2 runs from fire wall to top of engine. This is the heater inlet hose.” :bang:
| Prestone®
My install:
| Prestone®
1998camarossclone
09-03-2015 08:30 PM
libertyforall1776
10-18-2010 01:50 PM
