Prestone Flush Kit Install Guide- LS1 engine Camaro
1 Attachment(s)
Since the information is not easily found, here's a great little guide for you all installing a Prestone flush kit in your LS1/LS2 engine:
A = Water pump outlet to heater core, 5/8". B = Water pump inlet from heater core, 3/4". <-- hose where the tee goes, in the straightest area you can use! C = Water pump inlet / thermostat housing (in to engine from radiator), 1-1/2". N = Water pump outlet (out to radiator, from engine), 1-1/4". http://www.pirate4x4.com/tech/billav...S/IMG_5264.JPG My install: Attachment 46350 Clearly Prestone's guidance SUCKS! “Hose #2 runs from fire wall to top of engine. This is the heater inlet hose.” :bang: | Prestone® http://img827.imageshack.us/img827/2...neflushkit.jpg |
