Cams: Hydraulic or Solid: Huh?
Old 10-24-2007, 10:53 PM
PedalToMetal's Avatar
Default Cams: Hydraulic or Solid: Huh?
Whats the difference between a solid an a hydraulic cam? Frankly i have no idea.
Old 10-25-2007, 05:12 PM
94Z28SHAKER's Avatar
Default RE: Cams: Hydraulic or Solid: Huh?
biggest difference is hydraulic cams have roller lifters, solid have flat tappet lifters
Old 11-02-2007, 11:00 PM
bigjim's Avatar
ORIGINAL: 94Z28SHAKER
Not all hydraulic cams have roller lifters.The difference between solid and hydraulicliftersare hydraulic haveaninternal spring to set the lash.solid ( mechanical lifter) Need to have the lash set with a set offeelersbecause they are solidand there is no give to them when the cam ramps up.
Solid cames will usually have a bigger lift are are more for race engines or street strip cars. there is a lot more maintenance with a solid cam because you should set the lash every time you change your oil. And you'll need two people to do it right.
A hydraulic cam you set the lash and forget it but there not good for high revvingand can collapse and fail. I had one come apart and the retainer clip got into the oil pump and snap the oil pump shaft.
x01660
06-03-2011 11:23 AM
nnewquist
02-25-2010 02:37 PM
ScottD
05-17-2007 10:41 PM
GRIFF
10-16-2006 06:49 PM
GRIFF
10-09-2006 01:24 AM
Quick Reply: Cams: Hydraulic or Solid: Huh?
