97 LT1 upgrades
Old 06-01-2007, 12:32 PM
whammer3024's Avatar
ROTM Winner
Default 97 LT1 upgrades
hey guys...i got a 97 ss convertible which is a 30th anniversary car. motor is bone stock. i'm looking to add more horsepower. i guess my questions are what upgrades would you recommend to get the most bang for my buck? i'm concerned about doing the insides too much just because i want to keep the integrity of the 30th anniversary. any opinions would be awesome!
ps...i got about 2-2500 to spend on it
Old 06-01-2007, 12:57 PM
94Z28SHAKER's Avatar
Default RE: 97 LT1 upgrades
i would say get the basics, you basically have cold air intake already, get apolished aluminum intake elbow, BBK or HOLLEY dual 56-58mm throttle body,get a nice set of headers with performance Y pipe going to a nice cat-back magnaflow exhaust system.
what kind of trans? if its an auto get a higher stall Tq converter and 3.73 rear gears.
if its a stick then get 4.10 gears and cags switch.
get a new performancetq mount, panhard rod(s) performance lower control arms bigger rear tires,
and get a good dyno, or mail order tune, that should be good for a while.
the second step would be new valvetrain/ rest of the bolt-ons.
Old 06-01-2007, 08:51 PM
BigNic's Avatar
4' 11" 117 lbs of fury!
ORIGINAL: 94Z28SHAKER
X2
Old 06-09-2007, 11:29 AM
CamaroKid16's Avatar
I would say a pulley kit is a pretty easy, cheap and decent mod also. And a PCM flash at a local shop to take advantage of ur mods. I would say that covers alot of it!
Old 06-09-2007, 01:10 PM
The water pump, which is the big power user at high RPM is gear driven in an LT1 engine,and changing pulleys accomplishes nothing. However, you can upgrade to an electric water pump, and save a few horses. The other accessories, AC, alternator, power steering pump, do not react too well to being slowed down, and only draw power when needed.
Old 06-10-2007, 12:26 AM
Oh, i did not know that. i love this forum, i am learning so much!! thanks to guys like you pete. Good point tho!
jarrod1875
03-11-2010 09:04 PM
Skippysnax
04-09-2008 10:00 PM
DarkLotus006
04-10-2007 10:22 PM
Wrex Zero
02-23-2007 02:40 AM
953.4l
02-23-2007 12:20 AM
Quick Reply: 97 LT1 upgrades
