question about amp wiring
Old 12-01-2012, 09:47 PM
mutlyi4's Avatar
Default question about amp wiring
ok i was told wiring the high inputs on an amp for my internal speakers was a bad idea that i should use rca's is this true or was the guy just trying to sell me more stuff??
Old 12-02-2012, 11:32 PM
Scooch's Avatar
Super Scooch
January 2009 ROTM
nope, they are right. Ive always gotten better performance by going with the RCA jacks Pre-Amp level inputs on any Amplifier. Im an old timer, been doing it that way for the better part of 25 years.... I would have thought there'd be some super fancy hi-tech way of doing by now. But if your amp has RCA inputs.... Id use them.
Old 12-03-2012, 03:35 PM
Randy Bilyea's Avatar
I agree with Scooch here. If your deck and amp have the low-level RCA connections, it is better to use them.
It takes very little extra time to run the RCA's and the difference is noticeable.
Old 12-03-2012, 05:21 PM
mutlyi4's Avatar
ok thank you for the info
Old 12-11-2012, 09:09 AM
sugardiesel74's Avatar
Speaker Level Inputs are meant to be used ONLY as a last resource, for example if your source unit don't have RCA pre-amp outputs.
IronCactuar
07-16-2013 06:52 AM
mr.blue
10-07-2011 07:42 PM
endo
10-26-2010 07:17 PM
McGnrAcDcfan227
02-02-2010 07:30 PM
brenkate
10-20-2007 12:01 PM
Quick Reply: question about amp wiring
