98 Camaro Convertible
Old 04-20-2014, 11:04 AM
Danny Ill's Avatar
Default 98 Camaro Convertible
Hello everybody!
Could you tell me please, what pressure should be in 98 Camaro Convertible with 245/18R/40 sizes?
Thank you!
Old 04-20-2014, 02:48 PM
whats it say on the tire for max pressure? i run my 245/45/17s at 38, if memory serves max is 50.
Old 04-21-2014, 06:33 PM
libertyforall1776's Avatar
Look on your door jamb. Remember, if you inflate higher than recommended, you will experience a firmer ride and more NVH...
Old 04-21-2014, 11:15 PM
You forgot better gas mileage too, due to higher inflated tires having less rolling resistance. Find a happy balance between what the door sticker said and the max pressure of the tire. Car manufacturers may not want to prescribe higher tire pressures because tender bottomed owners would complain about a harsher ride.
Old 05-09-2014, 10:57 AM
Well my Camaro SS says 30 psi on the door jamb, the Owners Manual says run at 38 psi or max on the sidewall, whichever is less if you will be running at high speeds - so that's what I ran at Road America which easily gets upto 130 mph...
When you have more aftermarket suspension changes (lowering springs, SFCs, firm configured Koni SAs, etc.), having a more door jamb psi may help with ride quality for a DD. I tend to stay around 32 psi in general.
hdrocks
03-30-2012 07:18 PM
Andre
09-23-2011 01:35 PM
trev0006
10-30-2007 10:12 PM
rsmithline
01-22-2007 09:49 PM
Quick Reply: 98 Camaro Convertible
