interior Lights ?!?!!?
Old 09-09-2008, 08:21 AM
JaySan's Avatar
Default interior Lights ?!?!!?
ok so my interior lights went out ... But its only the heater and a/c area. What do i need to do to fix it???
Old 09-09-2008, 10:08 AM
Nessy's Avatar
Default RE: interior Lights ?!?!!?
you check the fuses?
if the fuses are fine, then it is probably either the bulb or possibly even the wiring.
Old 09-09-2008, 10:49 AM
JaySan's Avatar
which fuses do i check ??? Like what would be the name . I looked atthe manual but i couldn't figure it out
Old 09-09-2008, 12:48 PM
sallo's Avatar
i would say its the bulb if its the fuse itll be in the panel on the side of the dash drivers side, theres not many just check all of em if you dont know which 1
Old 09-09-2008, 07:57 PM
02StanGT's Avatar
Remove the trim that goes over the radio. Unbolt climate control panel. Remove old bulbs to see if blown.
MartineZ28
04-27-2012 07:59 PM
MyOtherRide'sAVette
12-12-2009 01:58 PM
bulls
07-07-2007 01:46 PM
bill12690
06-07-2007 09:48 AM
JHL88
02-11-2007 04:14 AM
Quick Reply: interior Lights ?!?!!?
