Lowering vehicle with driveshaft and torque arm disconnected
Old 11-04-2019, 10:40 PM
JustRebuilt's Avatar
Default Lowering vehicle with driveshaft and torque arm disconnected
I have a 99 camaro 3.8 I have the transmission removed but not enough room to pull it out from underneath the car. The car is sitting on four 4 ton jackstands (extended all the way). My issue being that the car is too high as of right now so its sketchy to lift just the front more, I thinks it might slide off the back stands. I have 2 ramps. So is it safe to lower the rear end onto the ramps with the driveshaft and torque arm disconnected so I can lift the front to gain clearance?
Old 11-06-2019, 09:04 AM
I set wheels under the wheels. also would use jack stands plus my two shop jacks at times always having multiple backups to catch the car if it went down.
Old 11-06-2019, 09:12 AM
I have some atv tires that I use, auto wheels should work even better if they are wide.
Old 11-06-2019, 11:23 PM
Thanks Craby, I appreciate your time. Have a great day.......
JustRebuilt
11-04-2019 10:34 PM
JustRebuilt
11-04-2019 10:29 PM
slick's camaro
02-09-2011 06:24 PM
dletner
07-01-2009 08:30 PM
clyon
05-02-2009 04:13 PM
Quick Reply: Lowering vehicle with driveshaft and torque arm disconnected
