97 camaro RS window stereo problems. HELP!
Old 08-29-2008, 12:55 AM
BlackToothJim's Avatar
Default 97 camaro RS window stereo problems. HELP!
The stereo sometimes powers on. If it won't power on the power windows will not work. (stock stereo) Sometimes the stereo powers up and stuts off kiling power to the power windows. I took the radio out and checked the wires for loose connections and it started working. Wellit worked for a few hours and when I turned off the car and re started itthe radiowould not power up again. I got the radio to come on and I hit the power window button and it killed the radio. I am at a loss anyone know a fix for this? Possibly a module or something?
Thanks for all your help
Jim
Old 08-29-2008, 11:02 AM
evilkal's Avatar
Default RE: 97 camaro RS window stereo problems. HELP!
Mine does the same thing... Which is a horrid event when you have a 90F day here and no AC
Old 08-29-2008, 11:26 AM
Bowtie Or No Tie's Avatar
i wouldnt be suprised if you had a ground problem.......
check 'em
Old 08-30-2008, 12:04 AM
I've checked the grounds, at least what I can find w/o a wiring schematic. Anyone have one? If there are a few on here with the same problem someone has a fix? Anyone????
Old 08-30-2008, 12:28 AM
02StanGT's Avatar
Retained Accessories Power (RAP) module, would be my guess. I have heard of similar symptoms from others, and that was what it ended up being.
Old 08-30-2008, 04:20 PM
skylinrcr01's Avatar
alternator maybe?
Old 08-30-2008, 10:57 PM
ok I tackled it today. I found the rap/bcm there are three different imputs. with the acc key in the on position, I just started wigglingthemolex imputs and the radio and windows worked. As soon as I let off forward pressure (towards the firewall) it stopped again. I just got a zip tie and tied around the blower fan wire harness. possibly a bad connection. I drove it all day with the t tops off, windows down and jammin to some pantera!!! Life is good. Thanks for all the advice.
Jim
Old 08-31-2008, 02:49 PM
02StanGT's Avatar
Glad I could be of some help.
timmay
11-19-2013 03:38 PM
mitchecw
02-10-2011 02:22 PM
lamppost
09-02-2010 08:59 PM
CamaroNut
09-26-2009 02:36 PM
swier629
06-15-2009 12:30 PM
Quick Reply: 97 camaro RS window stereo problems. HELP!
