1994 camaro charging system not working
Hello,My alternator wasnt chargine bat,so took it off and had it check it was bad.bought a new one hooked it up and still not charging.so took it back to be checked and alt is good.Putting out 14.36 volts.This is stumping me.Anyone with any Ideas.?I would appreciate it
thanks..
thanks..
no charge
yes I did clean all connections,and checked alt to ground its self it has good ground.does pcm control charging or is it the gauge that triggers it on the small red wire? since I do have the volts on that small red wire with key on.
With the engine running, check voltage at the output wire on the alternator (big red one), should be in the low 14's. What is the voltage at there? Then check at the battery. It's not uncommon to have a .5~1 volt drop by the time power gets to the battery, but if you're in the 12 volts range at the battery, the issue is with your wiring.
