Driver side rear sagging
So let me start with saying I've searched. All the threads I find are about the passenger side sagging and that fbodys often had this problem from factory or whatever. Well my driver side sags about an inch or so.
So any time I take a left hand corner somewhat fast (the weight shifts to the right wheel) or when I hit a bump at speed, my wheel has been scraping the inner fender lip. Taking mean slices out of the edge I had some used Koni's in the rear that I figured had started wearing out/the bushings were shot. So I bought some new KYB gas-a-just cheapies for the time being and it's still sagging. PS: I plan on rolling my fenders anyway regardless what I figure out the sag is from
I'm assuming it's my springs, but I just wanted to know if there's a specific bushing I should check first before assuming it's my springs.
Sagging is most likely caused by a weak spring or suspension damage, or a bent car. The tire scraping could be caused by the axle shifting due to problems with the panhard bar which holds it centered under the car, and/or over sized tires. and/or wheels with the wrong offset.
