o2 elminator
Old 09-27-2007, 10:12 AM
Z2896's Avatar
Default o2 elminator
i tried searching but found nothing. where can i buy the o2 elminators if i run an off road y-pipe
Old 09-27-2007, 12:13 PM
Default RE: o2 elminator
The O2 eliminators, usually referred to as O2 sims,take the place of the downstream O2 sensors (after the cat). They are available from Summit, Jegs, and other vendors. You still need the upstream O2 sensors in order for the engine to run properly.
Old 09-28-2007, 02:40 PM
jds88z28's Avatar
Old 07-22-2008, 10:01 AM
viciouZ's Avatar
You can basically make one for a few bucks. The second O2 sensor typically is not important for AFR readings, its only purpose is to detect a difference in exhaust flow (which will be impeded, by a catalytic converter) between the first and second sensor. So, all you really have to do is move the sensor slightly out of the stream of exhaust from the pipe. Some people weld on properly threaded nuts, tubes, or the little spark plug defoulers.
Old 07-22-2008, 02:20 PM
FUMULLETMAN's Avatar
Banned
Thats illegal, im fowarding this to the DOT
Old 07-22-2008, 02:29 PM
This is another thread that came back from the tomb! LOL
Old 07-22-2008, 03:00 PM
viciouZ's Avatar
don't trip mulletman! just answering the question, not promoting catless cars on the street.
Old 07-22-2008, 03:23 PM
Banned
Good because I would hate to have to report your redneck POS cars
Old 07-22-2008, 05:55 PM
73camaroSS's Avatar
wow why dont you let us know were you live mullet so i can kick your mullet dumb ***,go back to the ****ing crack house you *** and stop bringing up old post and talking **** before you get banned.[sm=icon_beat.gif]
Old 07-22-2008, 11:33 PM
SpecterGT260's Avatar
Ninja Administrator
oh, he will be banned, and the admin will check his IP against all other AFU sites.
