aftermarket radio help
Old 02-28-2015, 07:18 PM
warmeck's Avatar
Default aftermarket radio help
i have an aftermarket radio and i am strying to install it in my 94 camaro im having problems with it. i used to have a stock delco II loc system in there. i wired it up and im getting this like buzzing type noise coming from the speakers. i changed up one wire and now the radio wont turn on, i think i blew the fuse.
Old 03-01-2015, 10:55 PM
J-Factor's Avatar
First, check your fuses. Most head units have a fuse next to where the harness connects in addition to the one in the fuse box . Second, check to make sure your wiring is correct (http://www.modifiedlife.com/1994-chevrolet-camaro-car-radio-wiring-diagram/) and that nothing is grounding out that shouldn't. Worse comes to worse, take it to a shop and pay to have it hooked up.
Old 03-02-2015, 11:06 AM
If the car came with a Bose system, then the speakers came with individual amplifiers. If that is the case, then you have to install a set of normal speakers.
Old 03-02-2015, 05:50 PM
Jason Dukes's Avatar
Like the guy above said, if it is a Bose system you have to bypass the amps. I used to be an installer back in the 90's and if I remember correctly, there is no after market harness that allows for the use of the stock amps like there are for other cars, though things have changed since then. I just remember rewiring a lot of vettes to bypass the Bose system. You can use the stock speakers, you just have to by-pass the amps at the speakers. They are little black boxes attached to the speakers. If it is not amplified, then you either have a bad ground, or a bad grounding circuit inside the radio. I was also an electronics tech for many years and a bad solder joint inside the stereo can be the cause of that problem. Hope this helps.
Old 03-04-2015, 03:47 PM
warmeck's Avatar
got the radio isntalled its plays nice but now when i accelerate or my rpm rises theres a whistle that increases in sound when my rpm goes up. Is there any idea what this might be?
Old 03-06-2015, 12:06 AM
Typically that is introduced through a bad or loose ground. Is the system amplified or are the speakers running off the stereo itself??
Old 03-06-2015, 05:35 PM
warmeck's Avatar
so i got the radio hooked up and it worked for a couple of days and then i tried installing an aftermarket radio kit to make it fit in my gm dash and i was re-taping wires and all of a sudden the radio turned off and would not power back on. my wiring is good because it worked previously, i do notice that my door chime and my inside lights dont turn on anymore when my door is open; could this be a bad fuse? i also noticed while the radio was working everytime i do a pull and got up to higher rpm there would be a whine coming from the dash somewhere.
iDutchie
01-24-2012 06:57 PM
69SS427
03-13-2011 09:36 PM
Vandee
02-06-2010 01:13 PM
mofazfaz
01-10-2009 05:42 PM
gamesequallife
03-05-2008 03:08 PM
Quick Reply: aftermarket radio help
